Problem: VRaylights and VRayDirt
Is it known that (large planes of) VRaylight are seen by VRayDirt ? When I have a VRayLight in front of a (VRayDirty) wall within the occlusion range specified VRayDirt the VRayLight is seen as an object and casts a shadow/occludes !!! (Max2008, 32bit, VRay1.5sp2)
Yep, it is a known issue. I’ve made a note to try and fix it for newer builds.
If you check “work with transparency” in the vraydirt settings it will resolve this.
DlParisi, thanks for the tip. I thought I tried toggling all settings. This one works !!
