Problem - vrscene seq
finally after some time i manage to test almost everything and came up with interesting results,
the rendering (particle flick) probl is gone, but there is an another probl with rendering, here it goes:
here are the details on the probl
Vray particle render count
133mil particles - uses 21gb ram - 4 vrscene
naiad pts cache01 - 10271703 particles
naiad pts cache02 - 41968383 particles
naiad pts cache03 - 46583411 particles
naiad pts cache04 - 34664219 particles
Render Script:
from vray.utils import *
for ii in range(1, 2):
    frame1=‘pts_cache01.%04d.vrscene’ % (ii)
    frame1=‘e:/vrscene/’+frame1
    print ‘loading:’, frame1
    appendSceneContent(frame1)
particles=findByName(‘Pts01’)
node=findByName(‘box01_ptsShape@node’)
if len(node)>0 and len(particles)>0:
    node[0].set(‘geometry’, particles[0])
    frame2=‘pts_cache02.%04d.vrscene’ % (ii)
    frame2=‘e:/vrscene/’+frame2
    print ‘loading:’, frame2
    appendSceneContent(frame2)
particles=findByName(‘Pts02’)
node=findByName(‘box02_ptsShape@node’)
    frame3=‘pts_cache03.%04d.vrscene’ % (ii)
    frame3=‘e:/vrscene/’+frame3
    print ‘loading:’, frame3
    appendSceneContent(frame3)
particles=findByName(‘Pts03’)
node=findByName(‘box03_ptsShape@node’)
    frame4=‘pts_cache04.%04d.vrscene’ % (ii)
    frame4=‘e:/vrscene/’+frame4
    print ‘loading:’, frame4
    appendSceneContent(frame4)
particles=findByName(‘Pts04’)
node=findByName(‘box04_ptsShape@node’)
so is there a way to optimise this and render more particles?
also vray waits a lot before render even starts ~10min per frame?
cheers
