Problem when saving IR and LC precalculations
Hi! I’m trying to render a scene, and I want to save time and memory usage so I tried saving the IR and LC. but when I loaded the saved IR and LC and make a render.. here is the output:
!( Uploaded with ImageShack.us)
My Vray for Sketchup version is 1.49.01… please help me.. thank you! :slight_smile:
see this post:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?63579-bug-and-solution-for-indirect-illumination-(irradiance-map)-autosave-issue
Whoah! thanks a lot sir! This so great and simple! Thanks again to you sir! I’ll try this great solution from you! :slight_smile:
