Hello there,
I’ve been experiencing quite an annoying problem with the batch render option. As usual, I create all my views on SketchUp, after setting up all my textures I hit batch render. After all renders are complet, only a few views match the views set on SketchUp. What I mean is that some of the renders are random views, sometimes the image turns out black, I imagine it is like a render from inside a wall or something. What is strange is that when I render the views one by one, there is absolutely no problem. It used to work well before, I don’t know where this error is coming from. Has anyone had this problem before? Any solutions?
Thank you in advance.
Hi @Arnaud_Decolle
Could you please advise what is the full version number of V-Ray for SketchUp (Extensions > V-Ray > Help > About)? Are you using any other 3rd party plugins?
In the meantime, could you please adjust SketchUp’s Animation settings by enabling scene transition and setting the seconds to greater than 0 and see if this resolves the issue?
Hello @georgi.georgiev , sorry for the late reply.
I’m currently on V-Ray 4.00.01 and SketchUp 2018. Yes, I use a couple of plugins for ages now and never had this issue before.
Also, my animations setting are disabled an all set to 0. I don’t see where else this can come from.
Thank you for your time.
@Arnaud_Decolle
Could you please download and install the latest V-Ray for SketchUp update (4.10.02) and additionally configure the animation settings as I have advised in my previous post and confirm if this resolves the issue?
