Hi! I have dark pixel probably coming from the AA when i’m trying to render object Gbuffer and Materiel Gbuffer in RGB mode.
Perhaps you have an idea to solve the problem. I have tried the wirecolor masking but same problem with an RGB wire.
Attached the same element render in Vray with Multimatte RGB object
Hi, sorry but I do not fully understand the problem. Can you tell us more precisely what is the expected result and what goes wrong? What are you trying to achieve / what is the goal?
“I have dark pixel probably coming from the AA” - I do not understand this.
I can confirm this problem exists. It is caused by the image being saved with incorrect gamma - after applying gamma 1/2.2, everything looks correct. There are other bug reports on this topic, so I will close down this one as duplicate - see CGeometry_WorldPosition Exponential Values - Corona for 3ds Max :: Issues - Chaos Forum. We will try to find solution soon
