Problem with Corona scatters
When I have corona scatter in scene, and I try to create anything object it works some longer
When I hide all corona scatters and try to create something, max work normal.
Is it Normal?
Hi, which version of Corona is that?
As far as I understand Max becomes slow when you are using CSCatter + any other object, is that correct?
Is this happening even with “empty” CSCatter objects, or only if something is actually scattered?
yes.
I always wait about 2-3-5 minutes to add distribute object or change random seed.
Coronascatter works bad in 1.4
Have you tried if the same thing happens in the daily builds?
