Hi guys,
From some time I’m getting some problems with distributed/network rendering on Corona.
On both machines I’m using the same versions of 3ds max 2017.2 and Corona 1.7. So what happening.
Corona DR:
When I’m using Corona DR at the beginning everything is going well. Scene is being send, loaded, parsed etc. and the rendering is starting. After few minutes of rendering I’m getting an error: “3ds Max application has stopped working” and everything shut downs. This happens on every scene. I tried heavy scenes with a lot of displacement, scatter etc. and some simple with just Sphere and HDRI loaded. All the same.
LOGS:
a) Corona Log doesn’t give any error. Last line is like: “2017-11-19 12:59:14 Rendering pass 4”
b) Max Log doesn’t give any error either. Last line: “2017/11/19 12:59:11 INF: [12644] [12648] CORONA : Rendering pass 3”
c) DR Log. Here everything also looks normal with one exception. Last line: “2017-11-19 12:59:44 Closing loopback manager” - but it came out after I closed an error
Backburner:
When I’m using Backburner it’s basicly the same as above. Everything is going fine for around 5-10 minutes and then I get application error.
LOGS:
a) Backburner Server
INF Application is down
INF Adapter returned unexpected code - 2 for “C:\Program Files\Autodesk\3ds Max 2017\maxadapter.adp.exe” “-o” “ShutDown” “-l” “Info”
ERR Unknown Error
I’ve searched through internet for solution I get nothing
There was something about changing user in Services.msc, but I don’t have any Backburner or DR service there.
Maybe someone had similar problem and have solution?
