problem with DR rendering: render host released because there is no more pending work
I got the following message in DR rendering: “render host released because there is no more pending work”. The special thing on this server node is that it is virtualized on a Proxmox server. On an other server (not virtualized) the DR rendering works fine. Why doesn’t the DR work on this server host? Any ideas?
After testing around I found out that the option “Use Embree” in the vray settings causes the problem. When turning it off then the DR works on the Proxmox virtualized render node. What is the benfit of using “Use Embree”, or can you also turn it off?
Further testing showed that the Proxmox render server have to use the default host CPU settings. Now the “Use Embree” settings and the DR works.
