I have an issue opening my EXR files in Photoshop.
I save my passes as .cxr, then I open them in Photoshop via EXR-IO. Everything works fine with my cryptomates but I’m facing some problems: I can’t find my LightMix passes, and my Beauty pass is coming out without tone mapping.
Has anyone encountered this issue before? Perhaps I’m not following the right procedure. If that’s the case, could you please guide me on the correct steps to follow?
Note: The daily builds are the newest, experimental versions of Chaos Corona intended mainly for testing purposes and to showcase the recently added features. They contain the latest bug fixes but are not guaranteed to be stable, and in some cases can even damage scene files.
Thank you for the suggestion! I’ll test this with the Corona 13 daily build and check if it resolves the issue.
Voici une autre formulation :
However, I’m still facing the issue where Corona’s tone mapping is missing on Beauty EXR files opened with EXR-IO in Photoshop (even if I don’t have a LightMix).
It is expected that the Beauty pass does not have tone mapping applied when saving to CXR. When you open a CXR in the VFB or CIE, tone mapping is applied there. If tone mapping would be baked into CXR and then you would open it in the VFB or CIE, you would end up with double tone mapping.
