Problem with fire truck and liquids
Hi Is there efficient way to have fire truck spray water and have lots of water around it. If we add a giant sim box in front it will be massive amount of cells Thank you!
Hey,
With such a configuration you could either use two sims and mutually exclude them from interaction (the interaction list must be in Exclude mode for sim1 and Include mode for sim 2, or Max won’t allow a circular reference), or if the liquid will move from one sim to the other, then you can use a Cascade connection between the two (from the Grid rollout)
Cheers!
HI I never used cascade before. Do I have to simulate grid one first and then grid two or they can be both simulated at the same time?
Also is cylinder with surface force the best way to go for high pressure water cannon?
thank you
Hi Please disregard my previous post. I will have to simulate twice.
thanks
Hmm, can you send this setup over to Support? Is it with Phoenix 3.04?
