Hello everyone,
I have sketchup 2018 + vray 3.6 based on Windows 11 and I am using cpu rendering. One day I wanted to try cpu + gpu rendering and set it up.
From this time I have a problem with frame rendering. When I use frame rendering, only the frame is rendered, the rest is black. Sccreen attached.
Please help me in this case. Thanks in advance.
Please click on the region render(see attached scr shot) and let me know if this resolves it.
More information regarding this and other settings in the frame buffer you can find in the link below
No, it is working only in new sketchup files. It doesn’t work in files which were created before testing cpu+gpu rendering.
Can you please share an example file so we can check that on our end?
If this is ok please use this from(https://support.chaos.com/hc/en-us/requests/new) to upload the file. Make sure to add the forum topic so we easily link it to the forum post.
Of course, it’s done. Thanks.
Thank you for the provided file!
The issue you are experiencing is linked to the material in the provided file “Color M01”. To resolve the issue please delete this material from the SketchUp’s material editor.
Please note that this is fixed in V-Ray 5, you are welcome to download and test this(and other) file.
Latest version in the link below.
Let me know if the update worked on your end.
Thanks for info but it doesn’t work. Any other idea?
