problem with gradients when using LWF
this is vray light with gradient texture rednered with "don;t affect colors (adaptation only) also look the same when I set gamma to 1.
but scene is too dark so I prefer to use LWF
so with gamma 2.2
light looks like this:
and when I bump up light intensity:
Is there anyway to work around this to achieve first gradient with LWF?
This is more or less what I was asking yesterday. Vlado suggested to try ticking the “componsate camera exposure” in the VRayLightMtl. I havent gotten around to testing that yet, but maybe instead of a VRayLight you can use a plane with VRayLightMtl assigned to it?
I tried it doesn’t make any difference.
You will need to adjust the gamma of the gradient texture - pipe it through a Color correction texture with gamma 0.4545 or 2.2 (can’t remember which one right now).
its 0.4545 in advanced tab.
RGB Gamma -0.4545
like this:
Yes thats correct..
Gamma corrected to Gamma 2.2 now..
seems working :slight_smile: THANK YOU KINDLY GUYS !!!
