Hellow …am using Corona 4 and I need to render more than one camera in the same scene …so I added select light elements and assign the lights to it and then I saved the preset to use in batch render but unfortunately, all the lights I selected shown as delete …did anyone had same problem and how to fix it?
Can you please provide some screenshots or screen capture?
Hi all, I am also getting this same problem. In the render element tab when I light select and add all the lights which I want separately, then I save the preset because I want to render 15 cameras in my scene. please check the picture below attached all the light select (lights) are deleted when I use batch render with preset.
