Materials wont render… they just show up like this..help!
It looks that your objects aren’t UV mapped properly. Make sure to assign correct UV mapping to the objects and textures should show up.
well, what I can see in the screenshots is that the materials ARE rendered and ARE visible in the viewport, so not sure what exactly seems to be the problem
Rise sun position and it will looks better, also add corona sky in sun property’s if you don’t have it
