Problem with mixing multiSub and Vrayskinmt
Hi!
I have a problem with using wrayskinmtl in a multi_subobject, it doesn’t appaers in the render and it is completely black!
In other case, when the body have a unique shader of vrayskinmtl, without multi-subOject, it’s works perfectly!
The VraySkinMtl it is incompatible with the Muti-Sub?
Thanks for your answer
Would it be possible to send us sample scene for investigation?
Let us also know what is the exact version/service pack of V-Ray and 3DSMax.
VraySkinMtl works fine with Multi-Sum according to my tests.
Yeah of course, there it is.
It’s a simple scene with a sphere. I apply a Shell material, with two multi-sub in each, and the VrayskinMtl in the ID 1. We are in the version 3.00.04, on 3dsmax 2012 64 bits, version 14.12.508.0
And when i try to render this scene, the sphere is black
Works fine with Multi/Sub-Object material.
It doesn’t work with Shell Material - I’ll make a note about it into our system.
Okay, thanks, I thought that the multi-sub is the cause of the problem.
