Here is a version with the fluid only:
yes, the part that penetrates the wall disappears for sure. i’m thinking about different approach - stop the grid movement when it reaches the wall, but before the liquid contact. this means to disconnect the bottle and the simulator in this moment and the rest of the bottle movement will be performed in static simulator. this will ensure that no liquid will penetrate the wall, but there will be some liquid penetrating the bottle walls. you can of course use the same trick to remove it, or just let it go, it will take just one or two frames and may be invisible. this approach enables you to use wetting and the therefore a good burning track over the wall.
Understood. I´ll give it a try.
Right now I´m trying to make an advantage of the disappearing - to drive a static simulator liquid from the bottle liquid with as much liquid I need - with wetting - that spreads nicely around, wetting the wall - and therefore giving a good burning track again. I think for this second liquid I can use fuel to enable its burning feature…
…right?
Ivaylo, without your support I would have been doomed with this…
Ivaylo.
I tried this, but it does not work. The moment the simulator stops it seems that the liquid looses its speed. It just falls straightward down as if it wasn´t flying at all…
Did I get something wrong?
Thank you.
Sascha
EDIT: Uh, oh, wait, I had by accident some crazy amount of gravity in my scene…
I guess you increassed the gravity to have some weight for the liquid inside the flying bottle. If it wasn’t artisticly animated, the liquid should float inside the thrown bottle as it follows the same momentum .. or something… If my physics are not too wrong.
Animate-able?
No, it was because I tested around for the second iteration of liquid - additional drops emitted by the initial fluid - and I forgot to set it back…
Problem with animated playspeed
Okay, here we go: I have a problem with animated playspeed. When I make it too slow, I get this weird result:
Animated the playspeed down from 1 to 0 over 35 frames.
And if I do it over 10 frames it´s alright:
May this have to do with the fact that I animate nearly at the end of the sim-input?
I have a simulation from frame -100 to 300 - the keyframes for the playspeed 1 to 0 are at ff260 (1) and ff295 (0).
Does Phoenix need some footage around?
Thanks.
Sascha
what blending method are you using?
Hi Ivaylo.
I tried both - linear and velocity - both with comparable weird results - but it´s not that critical. I stop the playspeed much earlier before the simend and there it makes no problem…
nevertheless we have to find the reason for this behavior
Second that. Shall I give you the scene?
first we will try to reproduce it
Ivaylo!
Were you able to reproduce this behavior?
Sascha
not yet, but we didn’t try it, just scheduled.
Yeah, okay, if I have problems with that issue, I will report them. I have to do several more playspeed-animations due to a bullet-time-shot with 4 simulators…
Ivaylo!
An idea: wouldn´t it be great to have some proxy-functionality? My scene has now several sims with multi-million cells - an animating the scene is a real pain! If there was a possibility to use proxy-sims just for the viewport-display - with waaay downscaled resolution for the grid - that would be incredible!
It might be even possible to take the high-res-simulation to generate a low-res-version from that. So you have to simulate only once.
In the output-module there could be a “Generate proxy” option with half/third/quater/eighth settings - generating a similar named output with “proxy_half” suffix or something…
…and in the input there might be the usual proxy-functionality - “Use proxy” - “Choose proxy” - “use for rendering”, etc.
What do you think?
Sascha
yes, this feature is already discussed, and it will be implemented. of course not a different file, just a small copy in the same file.
Cool.
But doesn´t that mean that the whole file has to be loaded? With a sim with 80MB per frame - nearly 2Gigs/s @ 24fps the - HDD is the bottleneck - LAN is much worse. With several simulators of that size it gets horrible…
yes, the main idea is to skip the loading, because it is slow for large sims, even if no further processing is carried out
