There is an annoying problem with opacity map in Alsurface when SSS is enabled. It create a very nasty line at the border where there should be not… I spent 4h tor more trying to figure out what was the problem, I though it was mt gradient not smooth enouhgt, then a seams at the texture behind it etc.. to finally turn off the sss value and see the line disapears.
Can this be fixed please? Cannot have realistic eye with a sharp line in the transition.
Here’s the image to show the problem, the one in skin tone color is the sss2 and it’s working correctly with the sss2 and sss on. Only in alsurface when the sss is on it creates that problem.
