Problem with physicalcam exposure. Max2018/vray 3.6
Hi, switching from Max2016/vray 3.4 to Max2018/vray 3.6, I’ve some problems with the physical cam: changing Aperture/time/iso does not affect scene illumination.
Here some screens and the scene i’ve used.
https://drive.google.com/open?id=0B4tnXyn0A3DcRTNZdHk0SmtIS1U
It works fine here with 3.60.03 and 2018, here is a short video from my test:
http://ftp.chaosgroup.com/support/screenshots/2017-09-14\_13-10-11.mp4
I know that the scene is very simple but can you send it over for investigation?
The scene is in the google drive link above
Any news? I’ve sent the image @support and is linked above. I can’t figure out where is the problem.
In the scene you send us, if you go to Environments and Effects under the environment tab find Use Physical Camera Control if Available (which is on by default, you probably turned it off) and turn it on. Now you can change the exposure from the camera settings.
http://ftp.chaosgroup.com/support/screenshots/3dsmax\_2017-09-15\_18-28-22.png
Thanks a lot <3 !
