Problem with region render Kinda important
Hiya!
So I just finished huge render, and I had some minor adjustments to make, so I did some region renders.
Now in VFB I see my whole rendered image.
But when I save my file, I only get my region rendered and the other part is black.
I disabled the region render, and tried to re-save my file, and still it only saves the last part of the region render.
Corona 7
Max 2014
Any fix or am I doing something wrong?
Will be fixed
As for now, you can use this little workaround: after you do region render, uncheck region and use resume last option from action tab, let it render for a couple seconds, then stop and save render.
The feels T_T
Okay, ty, Its a fairly small strip, so it shouldn’t take more then 30 minutes or so. Still stupid because It was right there lol.
Th for quick responses :smiley:
There is a better way I think, just restart the default vfb (max’es). Then try to resave image, no need to resume.
But resuming the image would be also a good idea.
Ran into the region problem this morning, reloading MAX’s vfb and saving from it did the trick. Listen to this man!
