problem with Render in vray for revit 2016
Hi ramy2010,
Which is your V-Ray for Revit version?
vray_adv_35002_revit
There is a problem with some lights in Revit but the error does not give us much info.
Is this reproducible every time you render? If yes, can you send us the project, so that we can test it in our environment and investigate the reasons for this issue to occur?
Thank you,
Ana
this happened with every projects i try to render yesterday not only in one project
This one is a different problem. Is there an error popping up on attempt to export a V-Ray Scene file?
Please, do the following:
1. Open one of your own projects (i.e. a project different than the Revit sample project)
2. Try to reproduce the error
3. Once the error occurs, navigate to: C:\Users\username\AppData\Local\Autodesk\Revit\Autodesk Revit 20**\Journals (where username is your username and 20** is your Revit version; in case you use Revit 2016, the folder name will be Autodesk Revit Architecture 2016)
4. Order the journal files by date and send us the most recent one
Thank you,
Ana
this the new file
journal.0004.txt (1.72 MB)
did you find any solution of render error ???
i hope u find any solution
We haven’t found a solution yet, as there is no info for the crash in the journal file.
Can you please write at support@chaosgroup.com. Point my name as a subject.
Thank you
