problem with render resolution
Im probably going to ask a super stupid question, so dont punch me in the face please. :wink:
Im trying to render out a foam material:
This image is a fast preview render from a close viewpoint. You can see the displaced surface - everything is fine.
When i go to the final camera and render it out in 4K it looks like this:
Sorry, if the problem is not evident, but the resolution of this surface is simply not high enough, no matter what resolution i take.
Is it maybe no matter of resolution? Is it more a sampling issue? What can i do?
€: Oh any by the way: Already tried to increase the material sampels.
What is the distance between the camera(viewport) and first image and the camera with second image? with your second image is that a 4k image or have you cropped it to show the effect ? do you have DOF on in your 4k render? The further you move from the subject the less sharp it becomes-this happens in real life with cameras too. If it has nothing to do with camera distance or DOF then unfortunately I don’t know either.
I think it will be impossible to render a big object with such fine displacement from a distance. This would require lots of lots of lots of lots of polys. You will most likely run out of ram. I would use bump map for fine detail + displacement for bigger features if you really need it. You can also try increasing displacement settings, but… you will most likely run out of ram. :smiley:
What do you mean?
Image 1: 30cm
Image 2: 200cm
DoF is disabled, because i dont need it. Okay, so i better dont use displacement or such a fine alpha map here.
Sorry for crossposting now, but how would you recreate this material?
The view will be very flat:
I guess the most simple solution is just a good bump map.
I would go for bump map if you don’t need ultra-macro shot like the previous ones. Plus SSS if you really need it.
AFAIK blur/filtering is not taken into account for displacement. I may be wrong. Just checked and can’t reproduce what OP shows in 1st post. Fine displacement renders ok even if the objects are far away. Can you show material settings? What kind of texture are you using for the displacement?
Actually… Can we have material setup please? :smiley:
Sure, its indeed an opacity + displacement map. (same procedural shader ofc) I can setup the blur of the noise roughly, but now i think from this distance a displacement is not very effective. Creating a tilable foam texture + bump will be the best probably..
Thanks for mentioning it’s C4D version. :tongue:
Now I think it might be displacement OR as Rawalanche said filtering of opacity map. This should be easy to determine by disabling displacement/opacity and seeing which works how.
