Problem with Spawner (DR)
Im working in a machine, the client one.
A second machine is working as server.
I run the Spwaner in the server and works perfectly.
But I cant run the spawner in my machine, the client one.
The spawner starts but max open, aparentrly fails and close, and loop like that to the infinite.
Any clue?
I also try copyng the “good” net3dmax installation, the one on the server machine, but its the same.
Maybe an old plugin may be causing troubles?
In the client machine, the working one, I install and unsinstall severals plugins, just for trying them, I dont have them installed right now. That can be bodering?
Yep, same problem here eltioseba.
Can’t explain it either. Have tried uninstalling and installing again but no joy.
Is this a known Bug Vlado or just on some machines?
Am using XP sp2 and 3ds max 5.11
Any ideas appreciated.
Vu
TEMP path
You need to setup temp path from windows environment to c:\temp for all computers.
Vrayspawner may be start first, but don’t load second etc. if temp path place to other disk or dir.
I solved the problem reinstalling 3dmax in drive C:
I had it in D:
Dont know why, but now works.
It would be great if the nodes share the irradiance solution. Or better if all help to make it. Or if you could set wich node calculate the solution, the others stand by until it finish, copy, and use it. (without doing it manually :))
Or maybe I dont know the proper way to do it :frowning:
