Problem with texturepathes in R21 and new Asset Inspector
Hey Guys,
it seems that there is a problem with the new Project-Asset-Inspector in R21.
Since our whole office has to work at home now, i had to reconnect the absolute texturepathes we are using in our projects to a new hard drive.
I found out that cinema R21 is not saving these new texturepathes into the corona materials. after a couple of minutes it can happen that it is switching back to the old pathes. Even if you safe the project it is not overwriting and saving the pathes.
I already called maxon to this problem but they did not know anything about it (just asked if i have any plugins installed).
Than i tried arround and put all plugins out exept corona but still it shows this behavior. So i strongly think it could have something to do with corona plugin !
(A workarround is to open the file in R20, reconnect the textures, safe and open in R21 again.)
Cheers, sV
It seems you aren’t alone with this issue: https://forum.corona-renderer.com/ Relink of texture paths in asset inspector not possible
