Problem with the GI
I read this tutorial (Chaos: Industry-leading design and visualization software) for the GI but with the “same settings” I do not have the same result!
Where is the problem?
Re: Problem with the GI
In our default settings, we have to features enabled…the V-Ray Sun and the Physical Camera. You’ve disable the physical camera, but not the V-ray sun. Click on the M next to GI and Background…there will be a Sky map in there. Set the type to None and you should be fine. Once you change that, you can change the appearance of GI based on the color box thats in the options settings.
