Problem With Update Versions
I keep trying to install upgrade versions of Enscape for SketchUp (beyond 3.3) but when I install and attempt to initiate, SketchUp crashes. I have tried with SketchUp versions 2020 through 2022.
Thanks for your report.
Just to make sure, this occurs when you start SketchUp, correct? Can you also share a screenshot of me of any error message you receive potentially?
In any case, please also try to re-install Enscape again for “all users on that machine” as detailed here:
https://learn.enscape3d.com/blog/knowledgebase/getstarted/#advanced
If that makes no difference, please let me know, also submit us the following logs manually:
Enscape main plugin log files:
C:\Users%USERNAME%\AppData\Roaming\Enscape\Data\Logs
SketchUp plugin log files:
C:\Users%USERNAME%\AppData\Local\Temp\Enscape\Logs\EnscapeSketchupPlugin
You can just place the log files in a .zip and attach it with your next reply.
Thank you in advance!
