Problem with v-ray 3.7 when I start Material editor
Hello .
I installed Revit 2019 and V-ray 3.70. The v-Ray installation went well. V-Ray starts, renders. The problem arises when I try to run the material editor in a v-ray. The program crashes. Attached message. When I run the rendering it is OK. when I run the material editor outside Revit - that is, regardless of running Revit, it works. I also tried to do it with the version Revita 2018 - it also crashes. Is something wrong with the new version of Revit? I admit that I have not tried the material editor in Revit 2018.
Marek Krzyszton
Hi Marek, I responded to you in the private message you have sent. Please, check your messages.
