T he point is that I’m working with Revit 2019, and with V-ray 3.70. I’m running the v-ray and everything is OK. I can change all settings - they work OK with the exception of Asets Browser - settings and assignment of v-ray materials to Revit materials. Then Revit crashes. A few days ago I sent a bug report. In previous versions, it worked well. In this way, I attributed V-materials to Revit materials. I think that this is not the fault of Revit 2019. The same occurs in Revit 2018. This is not just about changing materials, changing parameters. The other options in this tab are also needed - even the color highlighting of unassigned materials - both v-ray and Revit. This is a standalone editor launch - it starts the selected material from the explorer - then it starts and we can change the material parameters. Maybe the 3.70 v-ray version has bugs, it is not fully polished. Previous versions worked well, except maybe the first 3.40 - then the lights did not render when Revit worked in a Polish location. It was necessary to change the language of Revit to English and work.
Regards Marek K
As I did not get the answer even from the manufacturer, which may be the reason for the above error when I started the v3.70 Assets Browser tab, I uninstalled the 3.70 v-ray version for Revit 2019 and installed the 3.60.3 version back. It turned out that here the problem when choosing Assets Browser does not occur. Tests with 3.70 v-ray were carried out on two computers - a stationary and a portable workstation. The effect is the same. Revit 2019 reports an error and the program stops working. Errors occur in cooperation with Revit 2019 as well as Revit 2018. Question to the v-ray producer for Revit: when can this error be fixed? Revit 2019 does not work with v3.70. I am paying the subscription for the Revit software (BDS package) and by (according to me) I can not work on the latest version of Revit 2019.
Greetings, Marek.
Marek, please, look at your private messages
Hi there, can anyone explain me - when i put on material from revit, later to make a render and add the vrmat material it showes on everything - walls, floor, roof ?
Hey,
Where do you put the V-Ray material? Can you please describe the problem by dividing it into steps? (step 1, step 2 etc.)
Also, a screenshot would be very useful for us to understand the issue correctly.
Thanks,
Ana
