Problem with VBF
I try to render scene, but no image in framebuffer just white background,
I’ve tryed reset scene and merge in to clear max scene, but nothing happen, the same problem,
When i use standart VBF all is fine!
Is this alpha v5 version?
Yes
Yes
and windows 8, geforce 6xx?
Windows 7 / GeForce GTX 285
weird, this happened some time ago with W8. Minimizing/maximizing helped
So, what should I do?
Have any idea how fix it?
Thanks.
I’ll try to apply the fix from windows8 to windows7. Lets test it later if it helped
Can you tell me about this? it’s Bug or other ?
Indrazulfi.
Looks like you are running out of memory or a graphics card error.
Maybe minimize → restore VFB..?
Sometimes I have the same problem (for example when I put all the windows down to the taskbar) in Max with the Frame Buffer. It’s a bit annoying and I don’t really know why is it happening (maybe something on my side - wrong driver, etc.), but the solution is easy, just maximize your window, and everything is running smoothly again :smiley:
Happens to me also, like they said, the solution is to double click on the frame buffer windows and it will appear again
I decided problem with VBF - uncollapsed modifier stack.
I had a lot of uncollapsed quad chamfer modifier stack о.О
Hi
I start to test corona render now , downloaded vray material convert script to corona material and convert my scene materials corona but I couldn’t find corona frame buffer window , can anybody help me ? So in this link Corona Doc | Corona Renderer there are the render settings corona render but this interface different form my interface and my corono version is Alpha V5 why my corona interface different from this link.Thanks a lot from now.
Hi
I just experienced this issue , where i have a see-through frame buffer, Easily resolved by clicking the corner and resizing the window.
I was also wondering if there is any way of reopening the frame buffer while render is still processing other than opening up the render setup, could a Show VBF be added to the main toolbar? Or is there a toolbar i haven’t opened?
Fallen
Edit: Please be aware my render time was just because i left it on overnight :smiley:
Can everyone experiencing this bug please post their operation system version? E.g. Windows 7 vs. Windows 8
I have the problem to on win 7 system (on multiple systems with this video cards: Quadro K4000, GTX 670, GTX 470). I solve the problem by zooming in on the frame. when i am close enough then the problem is solved…
Win7 64bit gtx680 same problem
