Sheen is mostly visible on geometry grazing angles. This is clearly visible on a large, smooth surface. But once you introduce more details, sheen becomes less visible, because those grazing angle surfaces become much smaller. Here is an example with spheres - sheen becomes less visible as you lower sphere size, despite the overall shape being the same:
In your examples, displacement has much lower quality in the “preview” due to lower image resolution, which results in more smooth surface. When you render finals, the surface becomes much more detailed and less smooth like in the sphere example above.
To fix this, you can try the following:
decrease displacement height in your material
increase sheen roughness
use more uniform lighting rather than directional
use the 3ds Max falloff map instead of Corona’s sheen - it works in a similar way, but is not lighting-dependent, so the brighter grazing angles will be more visible
Thanks for the explanation.
It’s definitely the displacement that’s causing the velvet to lose its sheen.
Unfortunately, I need the displacement map to achieve that “furry” or “pile” effect.
I’ll try using the falloff, as suggested.
I’ll leave you here what i have done for my first test.
As the last resort, you can also try lowering displacement quality in Render Setup > Performance to artificially make it smoother. If you are planning to render a sequence, switch to “world size” displacement mode.
I think one of the issues you are having, is because you are using displacement all the fur is pushed following geometry normals. To get the feel in your texture like in the photo reference, you need the fur to be displaced in a variety of directions. My recomendation is to use vector displacement (Just add the vector displacement from general maps)
A for-fun exercise with the newest Corona 16 preview build that turned out to be a masterclass in overengineering. Hopefully someone will find it useful.
Get a displacement (depth) texture that imitates tiny velvet strands
Use it as displacement in your material
Switch to parallax displacement - this way you won’t distort your geometry or fill up your RAM while getting virtually infinite detail
This kind of setup allows you to use additional sheen easily
Optionally: render an AO map for the same texture and use that to fake AO
The setup here is quick and dirty and getting the result you are after is very tricky
The appearance of such materials changes dramatically with scene lighting
It renders pretty slowly
The geometry has to be subdivided a lot, otherwise faces are visible like in the below examples
