problem with vraysun
Hi
I am using vray at office and have a problem when using a visible vray sun light. The rendering comes with a black circle around the vray sun which creates some ugly reflections on the water. Do you know what the problem might be?
Here is the link for the image:
Thank you for your help!
Mark
in the color mapping tick Clamp Output and subpixel mapping to fix this issue.
either that or switch to a non sharpening aa filter. or switch filtering off altogether.
Hey guys,
Thanks for the quick replies.
I’ve found that changing the AA filter to area works better than ticking the subpixel mapping and clamp output, because it keeps the sun reflection on the water.
Thanks again.
please contact the chaos group people and get them to give you full forum access since your a registered user
yes ml-a! How did you manage to get 221 posts without having full access to the forum???! Come on and get registered fully and lets see some image posts of your work and how you did it :slight_smile:
i have contacted chaos for this reason, but they did not get back to me! If you can fasten up the process I’ll buy you a beer.
Those 221 posts where made when the forum was free in 2004-05. Where was you at that time?
we were not saying to contact them about the problem. we were saying to contact them for full forum access that will reflect the status of you copy of vray. im not trying to be rude or anything but if you have been around since the days when you could post on the free and public part you would have known why those sections were locked. and if you have been around that long you would have had quite a while to get registered on the forum.
