Probleme with bump map in cloud rendering
I have a noise map in the bump map slot in a vray normal map that work well in my local render but it doesn’t work in the cloud rendering. It’s like no bump appear in th render.
Can someone explaine me how to fix it.
Many thanks,
Pierrick
Hi Pierrick,
Can you please share a sample scene which if rendered in Chaos Cloud reproduces this problem? Also if you can share a link to the Chaos Cloud job which has this problem, it would help. The best way to do that is by sending us a support ticket (https://support.chaos.com/hc/en-us/requests/new). Please let me know if you’d like me to help you with the support ticket.
Thanks,
Vladie
