I’m trying to bake an ambient occlusion pass for a real-time application.
However, on some objects I have this awful effect (see the end wall for example).
I have unwrapped, reset normals, reset xforms, tried different methods of AO (light material, override material, vrayambientlight, etc), but I can’t seem to get to the cause of the problem.
Your model has a lot of overlapping faces, which causes the bad AO output. You can easily resolve it by setting the Secondary ray bias (Render Setup> V-Ray> Global Switches) to 0.01.
