Hi
Recently I had to bake some NormalMaps for some scanned models and render using Vray and I’m not sure if there is a problem with tangent space normalMaps and V-Ray because I get very bad seams on my models.
I try almost everything that comes to my mind but I’m not sure if i´m missing something important. I try to use different bakers like ZBrush, Substance, xNormal, MAX and I get similar results to everyone. Really bad seams on the normals. I try to export FBX with and without tangent & binormals, OBJ, etc.
After trying a lot I decided to compare the results with other render engines and in Corona, OpenGl in SD, 3D Studio MAX viewer, UE, etc. I get perfect results using the same tangent normal maps. I was desperate so I tried MAX PBR material in Vray and to my surprise it renders without seams on the normal maps (images attached) but I need VrayMtl. I also tried Corona using VrayMtl and it works perfectly.
I would like to try Object-Space NormalMaps but i´m not sure if v-Ray supports these maps. I’m sure this will solve the problem.
I also was curious to see if other 3D Models like Megascans for example have the same problem and yes, all megascans models have very bad seams on normalMaps in vray but the same model look correct on other renders so i think i´m doing something wrong here. ¿Can anyone point me in the right direction?
I usually try to hide UV seams but in the models I need to make it´s not possible (this one it’s just for a test).
I did the test using a CC0 model so you can replicate the problem. Here is the MAX scene With the HP and LP models I use.
Download link
https://we.tl/t-p7ch7kEpXi
Thanks in advance.
Best!
VRay Results:
Corona (more images on the download link from Wetransfer)
