Problems Save Corona EXR Image with LightMixer
good day
If I want to save a light-mix scene as cexr I always get a error message? All other formats go? Anyone knows this problem.
I would like to save the lightmix scene, so I can later save different lighting situations.
greeting
funk24
what error message?
Error Creating File Output.
When I turn the render elements off it goes.
I need this but when I load the image again to save the different lighting moods.
oh - this is not corona’s fault, but rather bad design by 3dsmax: https://coronarenderer.freshdesk.com/support/solutions/articles/5000672469-i-am-getting-error-creating-file-output-message-
thanks for the answer.
I would like to open the room over night renders with backburner and the other day in corona and save different lighting moods.
Can I load the file into the VFB without further rendering?
I have run a test over backburner.
Image saved (common tab) as cexr.
The renderlemente paths I have deleted. But there is again an error message when saving?
Is there a possibility to save the file via (scene tab) save vfb with backburner, so I can let several scenes render?
So it looks like there is a problem with “error creating file output” specific to .cexr:
