I have a problem when i save an irr. map, in the vray rollout tells the irr. map size is 22 megabytes but whe i save the map the file is only 1,6 megabytes. If i use this file to render the image, vray gives me an error loading the ir map.
This is not the first time that happend to me.
What can i do?
And the reset map button in the irr map rollout doesn’t work here.
