Hi, when I opened the Cosmos Browser in Cinema 4D, it asked me to update. I did, and this is what I got. I downloaded cosmos_662281_osx_bigsur_univ.dmg from the website, but it still doesn’t work. I installed the latest version of VRay Stable from May 1st, but it still doesn’t work.What can I do?
Cinema 4D 2025.3.3 MacosX 14.6.1 VRay 72000 stable_33568
Hello, please create a ticket in our support platform, and attach the Cosmos log (/Library/Chaos/Cosmos/cb.log)
Let me know the ticket number so that we can review it ASAP.
Thanks for your reply, the ticket number is this Request You should look at this!
Don’t look at the post above, I messed up, the tecket number is this 482837
I saw the ticket, unfortunately the information is not enough. Can you please upload there all files (logs, config) from /Library/Chaos/Cosmos , without the localhost* ones?
In the meantime, you can also try the following in the Terminal:
sudo chown -R <your_user>:staff ~/Library/Application\ Support/Chaos
Then force-kill cbservice.bin from the Activity Monitor, and see if this will make it work.
Forgot to mention to replace <your_user> with your real username, in the command above
I solved the issue by replying to the ticket. Thanks everyone.
