Why? when I save an image in EXR format and then mount the sky in photoshop out jagged edges?
can someone help? setting problem?
thanks for your help…
this picture shows my problem.
and this is my exterior setting
Re: problems with png images borders, jagged edges.
its nothing to do with your settings, they have no effect. The only thing i could guess at, is that your output size is too small and you are enlarging them in PS to add sky, people etc. Try rendering a larger file size and avoid enlarging images in PS, this should sort your issue. In 2 years of using vray and saving as PNG’s ive never had to adjust settings etc.
Hope this helps
Re: problems with EXR images borders, jagged edges.
Hello deanfitton the actual size of the output image is 2500x1320 pixels, the image posted is just a crop of the original, where you see the problem …
other information I can give is I’m taking pictures in vrimg mode. maybe this is causing ragged edges?
i made a mistake EXR is de format, not png..,
thanks again
Re: problems with EXR. images borders, jagged edges.
it’s not gonna be fixed with anything, you just have to use the pen tool to crop those edges, as easy as that ![]()
in photoshop, you can use the matting tool:
Layer → Matting → Remove White Matte
this will get rid of your white border, but if you have areas of semi-transparent objects with the background behind, it can do some odd things in those areas.
Nice render! I like it!
just one word… WOW!
Hola Fernando que bueno que te guste la imagen mucho se debe a tus videos tutoriales que realemte ayudan y muchisimo!
arqestevez1 gracias tambien por tu apreciacion de la imagen!
saludos desde Argentina!
no, really, it’s a pretty nice image, hey, what about those trees behind your model, are those png images or is it a background?
could you share the sceene?
jeje te lo pongo en inglés porque luego hay muchos que no hablan español, estamos en contact ![]()
hi Omar…the background is postproduction in photoshop with simple images, and there are also some 3D trees in the front.
3d scene unfortunately I can not share is for a customer …
but if you want, I can send the scene without the building
3d model
background
Greetings
hey dude, don’t worry, i was just wondering how you made the background.
it looks really good with all those trees behind the model
saludos!!
