Problems with IES lights
https://www.youtube.com/watch?v=LIzGzLTeg-c
Hello, I have problems with IES lights in the video above to see that IES lights behave differently according to the modifications of the modeling. The same IES light has different designs according to its direction and height. By modifying the modeling the lights also change their design, making it impossible to represent various types of lighting in project images. There is a Whatsapp group called Enscape Brasil where more people are having the same problem. It would be great if they could give us a solution. Thank you!
https://youtu.be/LIzGzLTeg-c
Hey @vzsegala , is there any chance you could kindly send me the .IES file which is used in this particular example? As of yet I’ve not been able to reproduce this behavior with other .IES files.
https://drive.google.com/file/d/1M32cGfhvOIP5hyNcizSE-VkTvliFaLKb/view?usp=sharing
There it is, but in all sketchup files and regardless of which IES file is used, the problem happens.
If you change the height or direction of the IES, it also changes the light design.
Thank you so much for the file, I’ll get back to you as soon as possible once a solution for this has been found.
Thanks!!
Any solution? Version 2.8 preview 5 continues the same problem.
Not at the moment I’m afraid - I’ll be discussing this once more internally. At the moment, this is due to technical reasons, but I’ll let you know more again soon.
It usually happens when the IES does not have a face at its end. If the design of the IES does not go to the floor, or it is pointed upwards, this light cut occurs.
