Problems with light selection.
Hi guys, i have a question ,
So when I’m saving settings to make batch rendering, all lights in light select map are deleted, is that a bug or something are wrong in my computer ??
สมัครufabet
Any suggestion would be greatly appreciated.
ufabet
Thank in advance.
What exactly do you mean by
Could you send us step-by-step instructions about what you are doing, and what is expected?
Hi
Batch rendering sometimes overwrights the last place you saved your render elements (i don’t know if this is what you mean)
The way i “fix” this is by going to the render elements tab and manually deleting the output path from all of them. That way when i batch render they save to the same place that my batch render saves
I hope this helps
thanks.
928bet
เว็บพนันออนไลน์
