Good Morning every body … :(when i tried to render the Panorama files … i mean 360 VR i had some problems like it’s to bright i tried to make the FOV 359.9 or 359 it’s the same problem too much bright … please if any body can help how to fix this issue..
thank you.![]()
i think because the Vray physical camera has not been used. Fernando has workaround how to access the vray physical camera parameters. http://youtu.be/D3-TxEzW4sQ
mmm that’s weird, i have never had this problem. you have to chance the camera mode to spherical.
the other thing is to change the image output to a 2:1 proportion
