I hope that I will answer correctly
but there is a small problem, I’m not an English )))
but I hope to understand.
if I have very many lamping in my scene, just a lot, what can I do? if you have a lot of light bulbs they are affected by the speed of rendering very much! I created the exterior, and there was a lot of street lights, 200 pieces(corona light) and it is very much a halt render, render in primary rays walked hour, Further, I did not even continue.. geometry of many - grass, building on the background … ,but everyone say that the corona render despite of the number of light sources and geometries, quickly calculates all!
ок, as anything I decide the issue in this scene, is to remove most of the lamps, but a friend in the future would be so that all the lamps will need to leave?
What if there is any solution to this crown render settings? or what some other solutions?
I am assign white material all geometry in the scene, but it is dont help me! rendering is also long! I said wrong, I have in the scene is 400 light bulbs, but it still should not hinder the scene. Crorna may have a certain limitation with rays? because when i paste 150 lamps then is normal with the speed!!! types of lighting my scene - 150 corona lights sphere; 250 - standart photometric lights with corona shadows.
in the scene should not be instanced objects? all convert to proxy?
when i do copy the oblect i do instanses but i must do copy? tell me right way plz?
