Hi together,
just testing some things with the new max2012 and the SP1 Version for it and found maybe 2 little bugs.
- if u put a vray hdri into the environment slot and turning on show environment in viewport nothing is showing (if you pass it through a color correction node it works…but it should without like in max2011)
- the mapping type of the hdri is not showing correctly in the viewport, if your turn to maybe spherical it is shown wrong in the viewport but renders fine, if you use maxstandard it is show right in the viewport but rendering did not fit…
hops this could be fixed..
thanks for all chaosgroup team!
cheers,
Jens
