Hey guys,
I’ve got a problem with V-Ray Next GPU HDRI lighting. There is a floor in my scene set to matte alpha -1 and a desk on top. A dome light with an HDRI attached. After rendering I saved the image with alpha, opened in Photoshop and put a white layer beneath it. And now I see not only the nice and soft shadows but also ugly parts of the HDRI leaking through. The problem is gone when switching from GPU to CPU renderer. See attached images. What can I do to solve the problem? Is there a workaround? CPU rendering is not an option, it’s to slow.
Regards
The image on the right is what you saved, yes?
Yes, the one on the right I saved png with alpha.
Well, the result is as expected, then.
You are saving the image with background from HDRI. When you apply the alpha, you will of course get it leaking through. Render again on black or white background, and the problem should be gone.
The noisy alpha shadow is a known one. I will bump the priority.
We have fixed the noisy alpha issue for the next update of V-Ray 4.
That’s good news, when will the update be released?
