I guess I missed the memo, but I see that ProEXR (and all the other fnord thingies) is now free. So now everyone can open .vrimg files in AfterEffects and Photoshop!
**** as long as you rename them to .vri first. ****
cool! thanks for the heads up!!
never had to rename them though
TXK for the info, downloading now ![]()
Yay! Thanks for sharing this news. I can confirm vrimg doesn’t need to be renamed (at least in CS5)
Holy crap, ok I admit haven’t used ProEXR till now but this is sweet! Just open the vrimg file with no renaming (in PS CS5 and CC2017 here too) and bam! its in there and all the elements are in layers! Im gonna have so much fun with this
ok yea Im a little excited lol.
does it work if you save out your render as an open exr? using CC2017… As i just get the beauty pass…?
You need to select the bottommost icon in the save image button, something like “save all channels” (I’m not in front of vray right now).
Yep ProEXR is an invaluable tool. The ability to read vrimg directly is vital because to this day V-Ray still can’t import an EXR with its channels in the vfb.
you’ll have to excuse my ignorance, but why would you import an exr into the VFB?
To be able to load a vrimg rendering in the vfb, do a region render and save the updated vrimg with all its channels.
Very useful when doing lots of last minute local changes on 8000 px renderings without having to re-render the whole image every time.
I find that I DO have to rename the .vrimg files to .vri for AfterEffects to read them, but not Photoshop.
I am thinking of adopting ProExr into my workflow. I had seen it was now free and regarded generally as an excellent product. I did notice on-the fnord site that the proexr creator links to features | Exr-IO free Photoshop OpenEXR plug-in
I want to try one or the other, anyone with experience with exr-io? Pro-con between the two?
here’s another ignorant question…
but if you render to a farm and set the output locations in the render settings in max, how do you get it to save all the render elements in the .exr file…? i’ve tried a few different things but every time i open it in photoshop with pro exr i just get the beauty render…?
Has anyone else had any luck important VRIMG sequences into after effects CC without needing to rename the files?
Anyone managed to open an exr in photoshop with this?
i replaced exr-io with this, but just get a spinning loading wheel forever without anything happening why I try to open an exr.
.vrimg’s work fine… haha
edit: nevermind, just that one file. odd.
Out of curiosity, why are you using vrimg files instead of EXR (either split elements or multichannel)?
Not sure, I thought it would be nice to have a workflow where I could render VRIMG files to a higher noise threshold, then resume it later with a lower one.
Thanks for the update
