Hi.
We have a custom display driver that is using RegionDoneCallback to fetch and send buckets over the network to a viewer.
This works great for bucket rendering. But now we want to add support for progressive renders.
Is it possible to get the image buffer at some progress intervals?
I’m not sure how you are making the connection with RegionDoneCallback, could you explain how you do it?
Regarding your question, have you tried running “vray vfbControl -saveimage <path>” ? Make sure your path is absolute though, otherwise your images may end up in the current working directory.
There are a few different modifications of the command, you can get more info if you run “vray vfbControl”.
The progressive sampler will call RegionDoneCallback::updateRect() with the portion of the image that was updated. If the region size is non-zero (i.e. x1>x0 && y1>y0) then you can grab the contents of the VFB by obtaining a PixelBufferInterface from the original RegionDoneCallback.
Have you overridden the regionDone method?
If you have then it will be called for drawing regions that are 1 line tall and their width should be the same as the image you’re rendering.
The method will be called for every scan line of the image. Please don’t make you code depend on the size of the region if you take this path.
These days the progressive sampler behaves almost like the bucket sampler in regards to drawing the image in the render view.
