Project integrate with 3D google map environment
Hello all,
Is it possible to position the Revit project in the google map enviroment, in order to be able to see the building in the real place?
See the image below..
Thank you!
@Marts If you want to set the building for an image in the environment you could perform the following steps:
  • Save the view of google map as image file
  • Add transparency to a copy of the image in e.g. Photoshop
  • Insert the image as user interface overlay in the “Customization” tab of the Enscape settings.
    → If the image has the right resolution size, it should fit your screen.
  • Now you can startup Enscape and adjust the view position so that the building fits in the right position on the image.
  • Take a screenshot, with Material-ID ticked in Capture tab of the settings
  • Place the rendered building on the wanted spot in the google map image.
If you want to
  • place it as actual geometry in google maps or
  • load the google maps geometry meshes into the basic software solution or Enscape
you won’t be successful as its currently not supported. But you could have success with SketchUp https://forums.sketchup.com/t/google-maps-new-3d-view-import-for-sketchup/65369/5
Thank you for your answer!
Is the SketchUP free for this fonction?
sKetchup is not free any more. And since the photo-texture in google is taken by satellite from very exact direction You can make your view only from that direction..
