Nice improvements!
Sadly enough we’ve noticed that the animation export from the vray sun isn’t working anymore. In the past this was working and we’ve used it to animate the sun.
Is this a quick fix?
In the lower paragraph it says in portuguese “Insufficient memory resources available to complete the operation”
In the old beta I had no issues.
Just an update.
After clicking several times in “Ok” it finally launches. When opening a scene the same warning appears, and after clicking “ok” several times again, it opens the scene.
So, I’ve fixed this regression in our internal builds.
We will update the build, most likely on Monday, possibly with some other fixes as well.
Stay tuned for a message here that the build has been updated.
Can you please tell me what happens when you enable noise threshold.
Just set it to 0.01 for example.
I suspect there is an issue with the noise update pass, and if that’s the case, you should get a real crash when you enable it.
this seems to happen only on the latest nVidia driver.
We still don’t know if it’s something we are doing wrong or if it’s a bug in the driver.
But you go can go back to driver 446.14 to have it fixed.
Sorry for the inconvenience, we should have tested the latest driver before release and maybe delayed it a bit.
