Hello Follow my second job with Corona, criticisms and suggestions will always be welcome, I thank you …
Very good work …congratulations, few passes need the scene?
Hello thank renderbox, all scenes are with standard corona configuration, the approximate time of each scene was around two to three hours …
The only difference in each scene was the lighting, the noturtas scenes took longer …
