hello all i was wondering if anyone knew a way to create those advertising lights that project the advertising onto walls givign u the transparent glowing affect you see of a light projected add or text. Does anyone have any solutions?
I´m not shure if i understood what you mean..
but the max standard lights have a “projection map” slot
in the “advanced parameter” rollout. There you can load
pics or anims as light projectors.
Together with a volume light
you get these nice ray/beam effects.
thanks everyone for your response. I cant find an image right now however ive tried the advanced transparency material method and it seems to be working.
I originally tried the spot light projection however that didnt give the glowing hazy affect i was goign for.
Its basically liek at a trade show where there are projectors in the ceiling where they project images onto walls or floors like logos etc. and they move around and they always to me looked like they were glowing and kinda fuzzy.
thank you all so much for your input i shall try them .. i just found that the spotlight projection seemed to just not mak it look like the image was being cast as a light i could be wrong… i shall try again
those rays are made by using a modified (greyscale, with pumped up contrast) of the same same render (without the rays) applied to the light as a projector map after being flipped and shifted with just a standard max volume light effect .
