Hi all
I try to put up a spot light that is suppose to be used as a projector. I also like to use VrayEnvironmentFog to make the light show the dust it passes through (The effect is made stronger in the example image so it is easier to see).
I have no problem doing it with the light put on directional (the yellow lines), but the moment I turn the directional value down (The pink lines) the projector animation that is shown on the wall disappears. I have read the documentation at it is said that it will have to be directional, but I wonder if anyone has manage to make a work around for this?
My goal is to have a projector and the illusion works when I don’t have “fog”, but when I use fog then it is obviously to see that the projector light is not comping from the lens (the black box at the light source in the image) of the projector.
Br
Harald Martinoff
Hi, I would take a standard spotlight for the fog of the light rays from the lens and (dont know if it would project a sourcemap correct) the invisible vray light as you have here. But only Max´´ s standard spotlight is capable to make nice rays in fog like this. Vray is diffusing its light right away when you open the angle.
I had the same prob and that was it I came up with. Maybe one of some solutions… =)
Thank you Caypiranah
Of course! I get so stuck in everything Vray that I forget that Max has its own lights and solutions when it comes to this. Will test it out, but still strange that Chaos has not built option to make a proper Gobo light option with an angle!
Br
Harald Martinoff
Yes, same to me often. =) Sometimes tend to get stupidly stuck on something, and forgot to look over the tellerrand finding something obliviously
Glad you found a solution.
all the best,
Kay
